2001 Dodge Dakota No power to radio and Turn Signals
2001 DODGE DAKOTA
DAD OF 4
Electrical problem
2001 Dodge Dakota V8 Four Wheel Drive Automatic
The truck will start with no problems and idle just fine. what is going on is if you want to listen to the radio or operate the turn signals you have to turn the key, in the cylinder lock almost all the way to the start position. I have replaced the cylinder lock and this did not fix the problem
Sep 17, 2010 at 12:57 AM
  • 110,244 POSTS
Have the ignition switch (not the tumbler) checked.
Sep 17, 2010 at 1:08 AM
DAD OF 4
How do you go about checking the ignition switch? do you meter it?????? if so what are the readings on should be seeing
Sep 17, 2010 at 1:35 AM
  • 110,244 POSTS
The switch is on the lower end of the steering column. IT will need removed. Then you need to check for continunity.
Sep 17, 2010 at 1:38 AM
DAD OF 4
Thanks for the assistance!
Sep 17, 2010 at 1:50 AM
  • 110,244 POSTS
Glad to heko. Let me know if you have questions.
Sep 17, 2010 at 3:27 AM
