1995 Dodge Dakota Blowing brake light and blinker fuses
169,000 MILES • V8 • 2WD • AUTOMATIC
BRANDON0221
  • 8 POSTS
I keep blowing the brake light and blinker fuses. First time it happened I just changed the fuses now it pops both when I hit the brakes. I know its probably a bad wire somewhere just wonderin if anybody has ran into this before and would give me a good area to start looking. thanks for any help.
Jun 12, 2010 at 11:15 AM
  • 110,248 POSTS
I would recommend starting at the light sockets. Make sure they are not shorting.
Let me know what you find.
Jun 13, 2010 at 5:43 PM
BRANDON0221
  • 8 POSTS
have checked the sockets and changed the suspect socket out with another and still blow the #7 brake light fuse then if i hit the blinker then the #11 blinker fuse pops i am going to ckeck the turn signal switch and have checked front to back for bad wires.
Sep 27, 2010 at 6:08 PM
  • 110,248 POSTS
Try this. Remove one bulb at a time to see if the fuse still blows.
Sep 28, 2010 at 3:24 AM
BRANDON0221
  • 8 POSTS
Finnaly just brought it into a shop and they could not find the problem although the mechanic got the fuses to blow for him. We discussed a little and decided to put in fuses that reset themselves which I am not a fan of, would rather just find the problem. But hopefully what ever it is goes out for good and produces a dead short. I have put in new bulbs and still blown fuses. When this whole problem began one rear tail-light was burnt out.
Oct 1, 2010 at 6:23 AM
  • 110,248 POSTS
The breaker fuse I don't like either. I have a feeling you have a bad socket.
Let me know when you find it.
Oct 1, 2010 at 4:38 PM
ROBERT KREBS
Check your towing connector. Make sure the wires are not shorted or oil f they are capped make sure the caps are on correctly. That problem will blow the fuse when you hit the brakes. Simple fix if its that
Oct 5, 2018 at 2:54 AM
