1998 Dodge Caravan Transmission Slips
Sounds like a selonoid was sticking and then unstuck while it was in the higher RPM area. May have damaged gears inside the transmisison.
Suggested Repair
Fill the transmission with the correct fluid (Valvoline MaxLife or Mopar ATF+4) and have it inspected. Low fluid may have overheated and damaged the transmission internally, including a sticking solenoid or gears; avoid driving it until a mechanic checks it.
Conversation Summary
A 1998 Dodge Caravan with about 150,000 miles and a recently replaced transmission clunked in reverse, shuddered, and then moved poorly in drive with no visible leak. The owner later found the fluid very low and the van would not move. After adding nearly three quarts it moved forward sluggishly and reverse was intermittent. The expert said these transmissions need the correct fluid and filter service about every 15,000 miles, advised filling it with Valvoline MaxLife or Mopar ATF+4, and suspected low fluid had burned the transmission internally.
