2003 Dodge Caravan Shift Problems
STEVE1155
2003 grand caravan, 115K miles, 33.3-Liter V6 OHV Engine
Been to 3 dealers and 2 independents, no one can fix the problem
Intermittently in the AM the car will not go into gear, I wait a couple of minutes and then it will go into gear.
Then for the next couple of days every time I am decelerating you can feel the transmission downshift, the car jolts like I was hit from behind.
After a couple of days the car acts normally.
The transmission computer was replaced but that did not help
Thanks
Steve
805-559-3161
Nov 9, 2007 at 6:21 AM
  • 75,988 POSTS
Did anybody bothers to check the throttle position and vehicle speed sensors-these sensors inputs tell the computer as indications of throttle and governor pressures and in turn the computer commands shifting solenoids to shift/lock/down etc.
Its like the transmission range sensor-if the computer don't recieve the positon of the gear-how will it know to operate the transmission properly
The computer is program when it sees something is has to make something happen, that's how the computer works in an electronic controlled transmission.
Nov 11, 2007 at 9:10 AM
STEVE1155
thanks very much for the advice, I don't know if anyone ever did but will make sure it is done
Steve
[quote:bb45eb5532="rasmataz"]Did anybody bothers to check the throttle position and vehicle speed sensors-these sensors inputs tell the computer as indications of throttle and governor pressures and in turn the computer commands shifting solenoids to shift/lock/down etc.
The computer is program when it sees something is has to make something happen, that's how the computer works in an electronic controlled transmission.[/quote:bb45eb5532]
Nov 12, 2007 at 12:12 AM
Suggested Repair
Check the throttle position sensor, vehicle speed sensor, and transmission range sensor. These inputs tell the transmission computer when to command the shift solenoids; the transmission computer was already replaced without fixing the issue.
Conversation Summary
The owner of a 2003 Dodge Grand Caravan reports that it intermittently will not engage gear in the morning until after a short wait, then jolts harshly on downshifts for a couple of days before returning to normal. Replacing the transmission computer did not help. The expert recommends checking the throttle position, vehicle speed, and transmission range sensors that control shift commands.
