1997 Dodge Caravan Transmission Leak
HAWAIIINSOMNIAC
I posted before because my car was not catching when it accelerated, I found out that the transmission fluid was dryer than the Vegas Desert. I have put some in my van, any recommendations for stopping the leak?I don't want to get a new car, this is paid off and I just use it to surf. Everything else run perfect.
Oct 2, 2007 at 10:46 AM
MERLIN2021
  • 17,250 POSTS
Find out if it's a seal, or the pain, or the control module on the top...clean it at a car wash with the degreaser brush, then let it idle while you look around...A lot of trannys leak after a pan is removed for a new filter, this is because you must remove the sharp edges around the bolt holes. I use a socket under the hole and tap the hole with a ball peen hammer, this flattens it and removes the edge...
May 21, 2021 at 7:58 AM
Suggested Repair
Clean the transmission with a degreaser brush, then idle and inspect to see whether the leak is a seal, the pan, or the top control module. If the pan was removed for a filter, flatten sharp edges around the bolt holes before resealing.
Conversation Summary
The owner of a 1997 Dodge Caravan found the transmission nearly empty after it failed to engage on acceleration and wants to stop the leak without replacing the paid-off van. The expert advises cleaning the area and inspecting it while idling to identify a seal, pan, or top control-module leak, and notes that pan leaks after filter service often come from sharp bolt-hole edges that should be flattened.
