1999 Dodge Caravan Stuck in First Gear
CAT67SPYGUY
I have a 99 Dodge Caravan sport. It has 177,000 miles (most are highway). A few nights ago I came into town and stopped at a red light. As I started forward my speedometer went to zero and (stopped functioning) and the van seems to be stuck in 1st gear. It drives fine, but wont' come out of first. I checked the computer codes and found the following:
700 - Transcontrol system malfunction
(listed twice)
500 - vehicle speed sensor A malfunction
(listed twice)
731 - Gear #1 Ratio incorrect
720 - output speed sensor
Do I need a new transmission?
thanks
jb
Apr 23, 2006 at 6:11 AM
VANDRAGON
  • 298 POSTS
it's stuck in limp-home-mode. the problem is the output speed sensor if the speedo doesn't work.....good luck....vandragon
Apr 23, 2006 at 7:50 AM
CAT67SPYGUY
jb
Apr 23, 2006 at 10:13 AM
Suggested Repair
The transmission is in limp-home mode. Diagnose and replace the output speed sensor, which also explains the dead speedometer and related speed-sensor codes.
Conversation Summary
A 1999 Dodge Caravan with 177,000 miles lost speedometer function and stayed in first gear after stopping. Codes included transmission control malfunction, vehicle speed sensor A, incorrect first-gear ratio, and output speed sensor. The expert said it is in limp-home mode and pointed to the output speed sensor because the speedometer does not work.
