1999 Dodge Caravan Transmission Leak
BILL MCDOW
My 1999 Dodge Grand Caravan has 167,000 miles and a few leaks. I see transmission fluid coming down from the bottom of my transmission near the Torque converter. Is this a common place for leaks or should I keep looking for the source. Also, how should I fix it?
Jun 7, 2007 at 4:48 AM
E40WATER12
  • 522 POSTS
Best for my self to find where tranny fluid would be leaking, from would to first try and degrease, the area first.Then then from there you could try to pin point the location, Usually the tranny pan gasket leaks or the yoke tranny shaft outter seal goes near the torque converter, Then the tranny has to be pulled to change that, Or outter Cv shaft, on the tranny could has a leak.
Good Luck.
Jun 7, 2007 at 7:38 PM
Suggested Repair
Degrease the transmission area first so the leak can be pinpointed. Common sources are the transmission pan gasket, the outer shaft or yoke seal near the torque converter (which requires removing the transmission), or an outer CV shaft seal.
Conversation Summary
The owner of a 1999 Dodge Grand Caravan with 167,000 miles sees transmission fluid coming from the bottom of the transmission near the torque converter and asks whether that is a common leak location and how to fix it. The expert recommends degreasing the area first to locate the leak, noting typical sources are the pan gasket, the outer seal near the torque converter, or an outer CV shaft seal.
