1997 Dodge Caravan Transmission Fluid Leak
DOUBTIT1
I have a 97 dodge grand caravan 3.8 with 110000 miles on it . I recently had to have the cooling fan replaced and a day or two later my transmission started slipping. i checked the fluid and it was low and added some but now i notice little puddle droplets under my car of transmission fluid and its still leaking. is it possipble when they replaced the cooling fan that they may have cracked or lossened the transmision lines so that they are leaking. thank you
Aug 16, 2007 at 5:06 AM
SERVICE WRITER
  • 9,123 POSTS
It's possible. Need to see where it is leaking. It also may have been due to the lines age that it couldn't handle any stress..which I wouldn't necessarily fault the tech for. To lose that much fluid in a day or so, it would be coming out pretty good. Take it back and talk to them.
Aug 16, 2007 at 6:27 AM
Suggested Repair
Return the van to the shop that replaced the cooling fan and have them locate the transmission fluid leak. The cooler lines may have been loosened or stressed, or they may have failed from age. Do not keep driving with low fluid.
Conversation Summary
The owner of a 1997 Dodge Grand Caravan 3.8 noticed transmission slipping and a transmission fluid leak shortly after a cooling fan replacement. The fluid was low and still dripping. The expert said the fan work could have disturbed the lines, but age-related failure is also possible and not necessarily the technician's fault. They advised finding the leak source and taking the vehicle back to the shop.
