Cut off while idling and will not start back up
100,000 MILES • 5.0L • V8 • 2WD • MANUAL
ROLLINSAERIC
  • 27 POSTS
I was not letting the car idle and it cut off like I had turned the switch off. it turns over and acts like it wants to start but will not start.
Jan 25, 2018 at 3:14 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Perhaps you popped the fuel pump fuse.
Can you hear the fuel pump run for about two seconds once you turn the key to run, before you turn the key to start?
If not check fuses 1, 2 and 10 in the fuse block, left side of the dash.
2 is for the fuel pump and 1 or 10 should be for the fuel injectors just in case the fuel pump does run.
Jan 25, 2018 at 10:47 PM
ROLLINSAERIC
  • 27 POSTS
It has a mechanical fuel pump.
Jan 26, 2018 at 1:53 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
So this has a carburetor and not the tuned port fuel injection?
Okay, have you checked for a spark yet from either of the spark plug wires?
Jan 26, 2018 at 2:12 AM
ROLLINSAERIC
  • 27 POSTS
Yes it has a carburetor and I did not check yet.
Jan 26, 2018 at 2:16 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, make sure you have a spark, then also look down the carburetor air horn with the air cleaner off, use one hand and snap the throttle open quickly and see if you can see a quirt of gas down into each front barrel.
Jan 26, 2018 at 2:19 AM
ROLLINSAERIC
  • 27 POSTS
It is squirting down both barrels.
Jan 26, 2018 at 2:21 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
okay, check for the spark.
Jan 26, 2018 at 2:52 AM
ROLLINSAERIC
  • 27 POSTS
Will do. also, I was about to wash the car when this happen I had sprayed it down and getting ready to move it and it cut off. just some extra information about the problem. Before then it ran fine.
Jan 26, 2018 at 2:57 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It sounds as though you probably got the distributor wet. I suggest you remove the distributor cap and dry out the inside and try again.
Jan 26, 2018 at 3:03 AM
ROLLINSAERIC
  • 27 POSTS
Will do.
Jan 26, 2018 at 3:09 AM
ROLLINSAERIC
  • 27 POSTS
I have no idea what it is but it crank up this morning I believe something was wet.
Jan 27, 2018 at 1:05 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It must have dried out on its own.
Jan 27, 2018 at 1:08 AM
ROLLINSAERIC
  • 27 POSTS
That is what I was thinking .
Jan 27, 2018 at 1:11 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I like to keep the engine running when I am power washing the engine so if the engine starts to stutter or misfire, point the washing wand away from the engine until it picks back up, then see what I was getting wet and remember to stay away from that. but I can tell you to try to stay away from the ignition as best you can and the opening to the intake or air cleaner if it is exposed.
Jan 27, 2018 at 1:16 AM
