First, is your check engine light on? If so, then you'll need to start there.
And this sounds like a fuel, not an ignition related issue. Check your fuel pump, filter, pressure regulator and injectors. (In that order)
If this checks out, then proceed with an ignition check beginning with the cap&rotor, plug wires, plugs and finally the ignition module itself.
Don't just remove/replace. That'll only be expensive. If you run into a suspected part, have it checked.
SPONSORED LINKS
Wednesday, January 20th, 2010 AT 9:06 AM
