1986 Chevrolet Camaro No Start
DEMERUS
Hi, i bought an old 86 camaro last week, and after some minor repairs (battery replace and plug wires replace) I had her going and going well on the road yesterday, except later in the day (when i was out of town of course) I parked at a gas station to pick up some oil (its a bit low). I went back to the car and turned the ignition.... and nothing. All the lights come on and I can hear the fuel pump going, but not a sound from the starter. Dosent even try to turn over. Perplexed by this, I opened the hood and couldent see anything, but then again I dont really know much about cars at this point. My brother, relying on the "kick the television set" mentality of repairs, just pushed up and down on the car a few times....and then it started no problem. This happened twice yesterday. This morning I couldent get it to start at all, same situation. Logicly im thinking it would probably be some sort of loose connection there, but since I dont know a helluva lot about the car yet, i decided that I would ask you guys :) Thanks in advance.
Oh, 2.8 v6 w/177,000 km on it.
Jun 13, 2007 at 10:56 PM
BACKYARDMECHANIC
  • 337 POSTS
Check the battery cables and make sure they are tight and clean. Also make sure the ground (-)cable is connected proplery to the engine block and body ground. Just trace the negetive cable to where it goes and you will find where it is connected. If the above is found good then the next thing is to check the connection at the starter. This will be a little harder to do. It will require getting under the car and tracing the postive cable to the starter. You will require car ramps and/or a lift to get under the car. Remember as a general rule of safety, never get under the vehicle while it is on a jack.
Jun 14, 2007 at 3:10 AM
DEMERUS
Thanks! Ill check that out when I get home.
After i -walk- home :(
Jun 14, 2007 at 4:17 AM
Suggested Repair
Check that the battery cables are tight and clean, and that the negative cable is properly grounded to the engine block and body. If those are good, inspect the positive cable connection at the starter using ramps or a lift; never get under the car while it is supported only by a jack.
Conversation Summary
The owner of a 1986 Chevrolet Camaro 2.8 V6 said it sometimes would not crank after recent battery and plug-wire work. The lights and fuel pump worked, but the starter made no sound; rocking the car sometimes made it start. The expert recommended checking the battery cables and grounds, then the starter connection, with proper vehicle support.
