PCM swap
  • 52,797 POSTS
No it does not. It could be wiring, the solenoid or a valve body issue.
Friday, September 4th, 2020 AT 3:46 AM
JAMESBURROW
  • 46 POSTS
When the engine is cool it will shift into 1st 2nd and 3 but when it warms up it will only shift into 1st and 2nd.
Friday, September 4th, 2020 AT 9:11 AM
JAMESBURROW
  • 46 POSTS
And sometimes it will jerk when it's in 2nd.
Friday, September 4th, 2020 AT 9:12 AM
  • 52,797 POSTS
Okay, we are off track here. Your original issue was with the PCM and engine.
We are off on the transmission and that will require you to start a new post as we can only deal with one issue at a time per question.
On the engine issue, what did you do about the low compression?
Friday, September 4th, 2020 AT 9:17 AM
