Cruise Control doesn't work?
CADIEMAN
  • 3,544 POSTS
I was testing the ground to the switch and voltage at the same time khlow.
Monday, October 26th, 2020 AT 12:27 PM (Merged)
SEAN03
  • 523 POSTS
Ok so I did what khlow and what cadieman said. I grounded one probe to the bady the grey wire came up with 0.01v. I put everything back together. I tested both sides like you said and their was power. I also hooked the two connectors and it was 12 volts on one side and 0.01 on the other and I flipped the connector on the other side and it wasthe same. So their is voltage going to the connector I would assume.
CADIEMAN
  • 3,544 POSTS
I know there is voltage coming to the connector because your reading voltage from the pink and black wires. This tests the voltage on the pink and it tests the ground to be good. Just test the opposite side of the connector the same. Look like blue and yellow and black stripe. Do u read voltage their going to
CADIEMAN
  • 3,544 POSTS
The lever.
CADIEMAN
  • 3,544 POSTS
Find the connector on the brake light switch with the brown and gray wires remove it and jump the brown and gray wires. Do u have a orange light then?This maybe is a misaligned brake switch or it is a bad 1.
SEAN03
  • 523 POSTS
Hey I had voltage their. How do I jump those wires. What do I need to do and then I guess I test it with the meter.
CADIEMAN
  • 3,544 POSTS
Do u have voltage on the brown and gray wires at the brake light switch connector?
CADIEMAN
  • 3,544 POSTS
Sorry been sick remove the connector on the brake switch. Then jump the connector with a piece of wire. Brown to gray. Does it engage?
SEAN03
  • 523 POSTS
Ok I will do this tomorrow. My grandma fell and broke her hip. She is in bad condition.
SEAN03
  • 523 POSTS
Ok sorry I have been sick since yesterday. They think I am having a reaction to one of the medicines I am taking. That's what they are hoping. I think I have scarlet fever. I have had scarlet fever 8 times and the doctors can't figure out why I get it so much. They are worrying about my heart when I get older. I will try tomorrow. It just depends on how I am feeling thanks for understanding.
SEAN03
  • 523 POSTS
I also wanted to say I hope you get better cadieman. Just take a few days to recooperate. I am in no hurry.
SEAN03
  • 523 POSTS
Hey guys I didn't want you thinking I forgot. I can't catch a break I got scarlet fever so I have been in and out of the hospital. This is my first time in awhile I have gotten this. I have had this 9 times in my life. The doctors were like that is not good they said when you get 40 we will have to check your heart every year because it does something to the heart valves and something else to the heart. I will do this maybe next week if I feel good.
KHLOW2008
  • 41,814 POSTS
No worries. We will be here all the time and watching the thread.
Get well soon.
CADIEMAN
  • 3,544 POSTS
Ya just feel better
SEAN03
  • 523 POSTS
Sorry cadieman I was using my phone and I accidentally pushed the flag for review button. I didn't mean to.
SEAN03
  • 523 POSTS
Ok so I did jump the gray and brown wires. I took a piece of wire put one on the wire strip and one on the other and it made no differance.
KHLOW2008
  • 41,814 POSTS
That would indicate the brake switch is not the cause of the problem.
We have been going around in circles and don't seem to be getting anywhere.
I did not go through all the post completely and might have missed out something so fill me in if necessary.
Is the Orange Indicator Light now showing when the switch is turned on? This light must be indicating so that the cruise control system is in standby mode for it to work when cruise speed is set.
SEAN03
  • 523 POSTS
No the orange light is still not on. Me and cadieman have checked power at the switch their is power going to the switch. I also tested both sides like cadieman wanted me to and I had power. I turned the car to the run position and pushed the off an warmer and let it go through then I turned the lever on and it shows E. 7.0 when I push the brake it switches from E.7.0 to E.0.0 same thing if you try to set it or resume. We just tried jumping the grey and brown wire on the brake switch. It made no difference the light did not come on.
KHLOW2008
  • 41,814 POSTS
You should get that resolved first as that is the main on off for the system. Without this light turning on, the cruise is never going to work, unless the problem is only a faulty bulb.
When switch is turned on, Check the Brown wire at brake switch for battery voltage.
SEAN03
  • 523 POSTS
Ok it had 11.5 volts I ground the back probe to metal and put the red probe on the wire.
