Cruise Control doesn't work?
CADIEMAN
  • 3,544 POSTS
Good night
Monday, October 26th, 2020 AT 12:27 PM (Merged)
SEAN03
  • 523 POSTS
Ok thanks I will do this tomorrow and let you know what happens. Thanks for the help today.
SEAN03
  • 523 POSTS
Ok so when I turned on the cruise it came up with e.7.0 then when I hit the brake and did the other things it said e.0.0 and it kept flashing back and fourth from e.7.0 to e.0.0
SEAN03
  • 523 POSTS
Hi I am reporting this message again. Ok so when I turned on the cruise it came up with e.7.0 then when I hit the brake and did the other things it said e.0.0 and it kept flashing back and fourth from e.7.0 to e.0.0.
CADIEMAN
  • 3,544 POSTS
What did do when u hit set button and the resume buttons
SEAN03
  • 523 POSTS
It just flashed to E.0.0 when I did it then it would switch back to E.7.0 real quick.
CADIEMAN
  • 3,544 POSTS
If the orange light isnt on the handle. You cant be getting voltage to the lever. Is the lever new?
SEAN03
  • 523 POSTS
I went to the junk yard and got one that worked. They told me it worked. I also have the original. I switched it to the lever I got in the junkyard. But I switched it back to the old one that is the original.
CADIEMAN
  • 3,544 POSTS
If u are sure their is voltage to the pink wire test the other side of the connector if power is good on both sides of the connector and the orange light doesnt light when you turn the cruise switch on youll need to buy a good lever. Gl
SEAN03
  • 523 POSTS
Which wires would I check for voltage color wise.
CADIEMAN
  • 3,544 POSTS
Pop the lever connector out in your pics. And test the pink wire for voltage on both sides of the connector. With a test light then u will need to ck the ground next stick a paper clip in the connector on the pink wire then put the test lights clip to it. Then probe the black wire at connector. If it lights the ground is good. Start here all testing should be done with the key turned on and not started
SEAN03
  • 523 POSTS
Hey I got a multimeter. Do I need to buy a tast light instead. Thanks.
SEAN03
  • 523 POSTS
I seen you posted to me but I cant see what you put. So I am reposting the question. I got a multimeter. Do I need to buy a test light instead. Thanks.
CADIEMAN
  • 3,544 POSTS
Key on test for voltage on the pink wire. Put the neg. On the black wire and pos. On the pink does it have over 12volts on the meter?
SEAN03
  • 523 POSTS
Their is 12.2 volts going to the pink and black wire.
SEAN03
  • 523 POSTS
Hey their is 12.2 volts going to the pink wire
KHLOW2008
  • 41,814 POSTS
That means you have battery voltage. Turn switch on and test the Grey wire for battery voltage.
SEAN03
  • 523 POSTS
Ok. I tested it I put the positive wire on the grey and put the negative on the black wire. It read 0.00 voltage. I also put the red volt meter wire on the grey and it still showed 0.00
CADIEMAN
  • 3,544 POSTS
Did u check for voltage on both sides because if power is going through the connector to the lever and the yellow light doesnt light then the lever is faulty.I dont know why your not setting codes 60 to 67 to help u diagnosis the system.
KHLOW2008
  • 41,814 POSTS
No, you don't test this way. The other probe should be grounded to body, not the black wire.
