2000 Cadillac Deville Cruise Control Switch
85,465 MILES • V8 • 2WD • AUTOMATIC
JAYBIRD1956
The cruise control switch will not stay locked on when pushed. I need to replace the cruise control switch. How do I remove the plastic cover that holds the switch in place? Are there any precautions I should take to prevent triggering the air bag?
Jan 14, 2008 at 5:54 AM
BUZZSAW
  • 1,198 POSTS
[quote:10868d6012="jaybird1956"]Other Category problem
2000 Cadillac Deville V8 Two Wheel Drive Automatic 85465 miles
The cruise control switch will not stay locked on when pushed. I need to replace the cruise control switch. How do I remove the plastic cover that holds the switch in place? Are there any precautions I should take to prevent triggering the air bag?[/quote:10868d6012]
the air bag has to come off, supposed to disconect the battery, but I never did, never had a prob, not saying you wont
Jan 14, 2008 at 8:07 AM
JAYBIRD1956
[quote:2a82497403="Buzzsaw"][quote:2a82497403="jaybird1956"]Other Category problem
The cruise control switch will not stay locked on when pushed. I need to replace the cruise control switch. How do I remove the plastic cover that holds the switch in place? Are there any precautions I should take to prevent triggering the air bag?[/quote:2a82497403]
the air bag has to come off, supposed to disconect the battery, but I never did, never had a prob, not saying you wont[/quote:2a82497403]
So how do I remove the air bag and get the plastic cover off of the steering wheel so I can get at the switch to replace it?
My steering wheel has two rectangular slots in the back at the top when the wheels are straight ahead.
There are no torque screws that I see.
Jan 15, 2008 at 6:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:38cca66fca="jaybird1956"][quote:38cca66fca="Buzzsaw"][quote:38cca66fca="jaybird1956"]Other Category problem
The cruise control switch will not stay locked on when pushed. I need to replace the cruise control switch. How do I remove the plastic cover that holds the switch in place? Are there any precautions I should take to prevent triggering the air bag?[/quote:38cca66fca]
the air bag has to come off, supposed to disconect the battery, but I never did, never had a prob, not saying you wont[/quote:38cca66fca]
So how do I remove the air bag and get the plastic cover off of the steering wheel so I can get at the switch to replace it?[/quote:38cca66fca]
back of the steering wheel, you need a 27 or 30 torque bit
Jan 16, 2008 at 1:32 AM
