Crankshaft position sensor?
ALEX1011
  • 2002 FORD F-150
2002 Ford F150
WERE IS THE CRANKSHAFT SENSOR LOCATED ON A 2002 FORD F150. 4.6LITER & HOW DO YOU REMOVE IT AND PUT ONE ON?
Monday, August 3rd, 2020 AT 12:12 PM (Merged)
DAVE H
  • 13,384 POSTS
Crankshaft position sensor:
Note: Engine design precisely locates Crankshaft Position (CKP) sensor. No CKP sensor adjustment is necessary.
Removal and Installation:
Disconnect negative battery cable. Raise and support vehicle. Remove A/C compressor to gain access. Disconnect crankshaft position (CKP) sensor wire connector from engine harness. See figure 5 . Remove CKP sensor mounting screws. Remove CKP sensor. To install, reverse removal procedure. Tighten fasteners to specification. See torque specifications.
https://www.2carpros.com/forum/automotive_pictures/266999_ckp_1.jpg
JUANC1009
  • 2000 FORD F-150
  • 6 CYL
  • 98,000 MILES
Im having problems with my 2000 F-150 V-6. Whats happening is, I go down the road and my truck starts hesitating. No power feels like its falling apart. I took it in to a local machanic replaced plugs , wire, fuel filter, crank shaft sensor, still no improvements.
MJR346
  • 132 POSTS
What about the coil if it feels like it's missing? Seen a few issues with the coils breaking down. Also have the technician road test with a fuel pressure gauge hooked up, the pump may become weak and when accelerated you are feeling low fuel pressure
JUANC1009
I forgot to mention, They also put in a new coil. They told me also that when the check engine light comes on, it gives him a code for the crank sensor. I will tell them about the fuel pressure, like you suggested. When its at an Idle it runs great.
  • 109,896 POSTS
Have they checked the catalytic converters> Also, you said they replaced the crank sensor and that is the code that is still coming up. Have them recheck the sensor to make sure it is good. If it is, have them check the wiring to the sensor as well as the plugs to it. Something could be breaking down in the wiring.
JUANC1009
Hey thanks for all your help. Finally figuered it out, It was the cam shaft sensor.
