2001 Ford F150 crank shaft bearings
2001 FORD F-150
400,000 MILES • V8 • 4WD • AUTOMATIC
SKYGUY10
hey i have to do the crank bearings on my truck and was wondering what is the easyest way to do it
May 25, 2009 at 2:27 PM
  • 31,937 POSTS
Hi there,
to do this job correctly you should remove the engine and have the crank measured to make sure that the journals will take the standard bearings, you may have to get them re machined and go 1st repair under size, this will help maintain good oil pressure.
Mark (mhpautos)
May 25, 2009 at 4:33 PM
