cranks no start
130,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
BIGALLOYMAN
  • 27 POSTS
i recently changed the alternator. the car started and ran like a champ, my wife pulled into a gas station it started to chug then quit, she thought she may have ran out of gas. she got pushed to a pump filled up the tank the car would not start. checked the fuel pump it is on with the key. what could it be?
Jul 25, 2016 at 11:10 AM
SATURNTECH9
  • 30,869 POSTS
So it cranks over normal speed, just does not start?
Dec 20, 2016 at 9:33 AM
BIGALLOYMAN
  • 27 POSTS
yes it cranks and i can hear the fuel pump. i was wondering could something have been bumped while doing the alternator?
SATURNTECH9
  • 30,869 POSTS
Anything is possible have you checked for spark and actual fuel pressure yet?
SATURNTECH9
  • 30,869 POSTS
Also has the timing belt ever been changed?
Dec 20, 2016 at 9:34 AM
BIGALLOYMAN
  • 27 POSTS
got spark, but i cant find the Schrader valve to check pressure.
BIGALLOYMAN
  • 27 POSTS
i put a code reader on car got a code of P0001 fuel volume regulator, there not a regulator in the fuel line could the camshaft or crankshaft positioning sensor be at fault
SATURNTECH9
  • 30,869 POSTS
Are you sure that's the code ?Iam having trouble finding that one for your car.
BIGALLOYMAN
  • 27 POSTS
i need to know what would shut the fuel pump down,would the chip in key stop fuel, or the camshaft position sensor. have spark, the connection at firewall fuel is present but no pressure the key fob works the locks the fuel pump was changed in Dec.i'm lost what would just shut down , the code was P0001 fuel volume regulator. found out after 2004 no schrader valve. fuel pressure is 35psi
SATURNTECH9
  • 30,869 POSTS
http://www.autocodes.com/p0001.html
Read the tech notes at the top of the link I posted.It say most manufactors don't use that code and could be a error from the code reader.Which would make sense because I don't see that code for your car.Also lots of things will cut fuel but you said you have 35PSi of fuel pressure.It recommends trying a different code reader.There are some China knock off code readers out there that are junk.The first I check on a no start is codes.
BIGALLOYMAN
  • 27 POSTS
the place a bought the fuel pump from said the code points to an electrical problem with the regulator i explained to them there isn't a regulator on that vehicle. but a co-worker asked about a inline fuel filter i thought it was on the pump
SATURNTECH9
  • 30,869 POSTS
That's crazy because it doesn't list that code for the car so it's really hard to say we need the actual code that would really help.so have you checked for injector pulse?We know it's fuel is the security light on solid or flashing with the key in the run position?
BIGALLOYMAN
  • 27 POSTS
not to sound stupid but how do u check for injector pulse
SATURNTECH9
  • 30,869 POSTS
You can rent a noid light kit from auto zone.You just unplug your fuel injector plug the noid light in where you Injector went.Then crank the engine over if you have pulse the light will flash while cranking.
BIGALLOYMAN
  • 27 POSTS
is a pulse what u want,and what is the difference with the security light
SATURNTECH9
  • 30,869 POSTS
Yes we want a pulse also the security light could mean it could be a the security system keeping it from starting.
BIGALLOYMAN
  • 27 POSTS
THANK YOU I'LL CHECK
BIGALLOYMAN
  • 27 POSTS
thanks for all your help got a new pump car is running fine
SATURNTECH9
  • 30,869 POSTS
Your welcome were here to help.
BIGALLOYMAN
  • 27 POSTS
sorry but the car wont start again i have 11 .7 volts at the fuel pump 12.7 at the battery with key on but with in a couple seconds the fuel pump shuts off but i still have 11.7 volts at the pump
SATURNTECH9
  • 30,869 POSTS
The fuel pump runs for a few seconds after turning the key to the run position then turns off that's normal.Also while cranking to start or with the engine running the fuel pump will run constantly.
SATURNTECH9
  • 30,869 POSTS
If you have power and ground to the pump it should run as long as you have both.
BIGALLOYMAN
  • 27 POSTS
after the pump quits i can check for voltage and i get 11.7 volts before during and after the pump quits. is the only thing that can be bad is the pump?
SATURNTECH9
  • 30,869 POSTS
If the fuel pump is getting power and ground the fuel pump should be running.
BIGALLOYMAN
  • 27 POSTS
the pump guy still swears its an electrical problem, so i asked him if the pump is getting voltage why doesn't gas come out of it. i got no reply he also said i need to get professional help i dont know if its for the car or me personaly
SATURNTECH9
  • 30,869 POSTS
So if you jump power and ground to the pump directly does the pump work?
BIGALLOYMAN
  • 27 POSTS
i'll try that let u know tomorrow
SATURNTECH9
  • 30,869 POSTS
OK let me know
BIGALLOYMAN
  • 27 POSTS
ran a jumper wire from the battery to the pump there are 4 prongs on the pump i get voltage at the middle two coming in to the pump but if i touch the jumper wire to the middle two prongs nothing but if i touch the outside two prongs pump comes on,it is not easy getting to the prongs they're about a half inch into the male side of the plug and trying to touch the connections with a fuel tank 3/4 full of gas and sparks coming from the jumpers as you make contact. i think my luck is running out.the fact that when i installed the second pump it started right u,then quit with the jumper the pump doesn't quit but when plugged in to the harness it quits but no fuel comes out ,either way but why does the pump quit is there some kind of safty switch that shuts off the pump if no fuel comes out after so long
SATURNTECH9
  • 30,869 POSTS
The pump only runs a few seconds when you turn the key to the run position then in the start position the pump will as long as your cranking the engine over.Also the pump runs as long as thee engine runs.That's the way most fuel pumps are supposed to run.
