2006 Chrysler PT Cruiser Car Won't Start
LAURA.SANDERS_85
  • 2006 CHRYSLER PT CRUISER
I started my car this morning. It was fine for about 10 seconds, then it shut off. Now it won't start at all. It will turn over, but it won't start. I have 3/4 tank of gas so I know it's not that, but what is wrong with it?
Tuesday, January 6th, 2009 AT 10:04 AM
  • 109,885 POSTS
Hi:
Is the engine getting spark and fuel? It almost soundes like the fuel pump stopped working.
Let me know what you find.
Tuesday, December 20th, 2016 AT 5:37 PM
LAURA.SANDERS_85
That's what I'm trying to figure out. I mean, I'm sure it's something wrong with the fuel line or something. Idk how to figure that out.?
  • 109,885 POSTS
To start, go to a nationally recognized parts store and rent a fuel pressure tester. Follow the directions on the tool as to how to check for pressure. If ther is no pressure, move to the fuel pump relay. Make sure there is power there. In fact, if you check closely, you will most likely find an exact relay running another component. If the part number is the same, switch them and see if you get fuel.
Let me know how that works. If you still can't get pressure, you will need to remove the fuel tank to get to the pump. Then you will check for power to the pump. If there is power, the pump may be bad.
