Chrysler Radio Fuse Battery Drain
CHRYSLER
IHATEMYCAR
radio fuse is blown & took it to the mechanic cuz I thought it might be something else. he told me he couldn't replace it b/c it would run the battery down...is this true?
Jan 27, 2006 at 12:49 AM
LOVESCARS
  • 359 POSTS
if the radio is wired correctly no it shouldn't drain the battery. if the radio is wired to play with the vehicle off as well as the ignition being off then yes it can drain the battery.
check with someone who specializes installing stereo's this person could have fixed this easily if the knew what they were doing.
Jan 27, 2006 at 12:58 AM
Suggested Repair
Have a stereo installation specialist check the radio wiring before replacing the fuse. A correctly wired radio should not drain the battery; a radio wired to operate with the ignition off can.
Conversation Summary
The owner asked whether a mechanic was correct that a blown radio fuse should not be replaced because it would drain the battery. The expert said a correctly wired radio should not drain the battery, but one wired to play with the vehicle and ignition off can. They recommended consulting a stereo installation specialist.
