1996 Chrysler Town and Country Fan Fuse Blows
Unless you see a bad connection, or a burnt wire, I would replace the fan. It is probably drawing too much current, and is old and tired.
Unless you see a bad connection, or a burnt wire, I would replace the fan. It is probably drawing too much current, and is old and tired.[/quote:63f1b5fdef]
Good info, Mikey... thanks. Any idea if a shop would consider this a "major" repair? The fan seems fairly accessible but I'm not sure I could tackle it. Any cost estimate would be appreciated! Thanks again.
Unless you see a bad connection, or a burnt wire, I would replace the fan. It is probably drawing too much current, and is old and tired.[/quote:63df8137ca]
Good info, Mikey... thanks. Any idea if a shop would consider this a "major" repair? The fan seems fairly accessible but I'm not sure I could tackle it. Any cost estimate would be appreciated! Thanks again.[/quote:63df8137ca]
I was looking at the manual, and the price of a new fan motor about dropped my jaw. Looks like the fan mator is around $350 from the dealer, and 1 hour labor to replace it.
here are the instructions for replacing it yourself...
COMPONENT REPLACEMENT, COOLING FAN
Raise and support vehicle.
Remove radiator outlet hose from mounting clips on fan shroud.
On models with auxiliary transmission cooler, remove lower fluid line from mounting clips on fan shroud.
On all models, lower vehicle, then remove air cleaner and ducting from throttle body and vehicle.
Disconnect electrical connector for cooling fan, then remove attaching screw for coolant recovery system from crossmember.
Disconnect upper radiator mounts from crossmember.
Mark position of hood latch on crossmember for later alignment, then remove latch and position aside.
Remove bolts holding crossmember to body, then remove crossmember from vehicle by lifting up, then forward.
Remove fan shroud to radiator retaining screws.
On models with auxiliary transmission cooler, remove upper fluid line from mounting clips on fan shroud.
On all models, disconnect lower left transmission cooler line from radiator and plug.
Raise and support vehicle, then remove mounting bolts for A/C drier unit, fan shroud and radiator mounting from lower right side.
Lower vehicle, then remove fan shroud to radiator retaining clips.
Remove fans and shroud from vehicle.
Remove fans from shroud as necessary.
Reverse procedure to install, noting the following:
Torque fan shroud to radiator screws and radiator to crossmember mounts to 105 inch lbs.
Torque , coolant recovery system mounting screw to 18 inch lbs.
Ensure proper alignment and closure of hood.
Check and correct fluid levels as necessary.
$350 for the part to a dealer? And they wonder why we never have anything nice to say about dealers?
Suggested Repair
Inspect the cooling-fan circuit for a bad connection or burnt wire. If none is found, replace the radiator fan motor, which is likely drawing excessive current. A dealer motor was estimated near $350 with about one hour of labor; aftermarket motors were reported around $105-$125.
Conversation Summary
The owner of a 1996 Chrysler Town and Country 3.8 reported continued overheating after replacing the thermostat, a water-pump hose, and coolant, then found the radiator fan fuse blowing within about 10 minutes. The expert advised checking for a bad connection or burnt wire and otherwise replacing the aging fan because it was probably drawing too much current. Labor was estimated at about one hour, with a dealer motor near $350 and aftermarket motors around $105-$125. The owner planned to have a shop perform the repair.
