concorde fuse to power outlet
CHRYSLER CONCORDE
INEEDANANSWER
i was using a portable air pump to inflate a tire. i plugged the power cord into the power outlet. after i was done the outlet didnt work. the questiuon is can i ruin the power outlet by using the portable air pump .
Oct 19, 2007 at 8:22 AM
2CARPRO JACK
  • 11,533 POSTS
Probably didnt hurt the outlet, may have popped the fuse. Using a test light, check all the fuses
Oct 19, 2007 at 8:35 AM
BLACKOP555
  • 10,386 POSTS
i needananswer please stop posting the same thing. youve posted 4 times already and youve been asnwered four times. keep it to a minimum please
Oct 19, 2007 at 9:22 AM
INEEDANANSWER
thank you for everything you guys rock
Oct 19, 2007 at 9:42 AM
