1998 Chrysler Concorde Speedometer and Gear Issue Fix
JAZZYKAT
I own a 1998 Concorde LXI, Engine 3.2 with 62,000 miles on it. On Tuesday, I was driving in to work and the speedodmeter quit working, the check engine light came on and it seems as if the car is not getting out of 2nd gear.
What could be causing this?
Thanks
May 17, 2007 at 12:26 PM
E40WATER12
  • 522 POSTS
I would first go to autozone get code scanned, My guess would be youre speed sensor is no good.
May 24, 2007 at 8:36 PM
JAZZYKAT
[quote:34bcb5f93b="e40water12"]I would first go to autozone get code scanned, My guess would be youre speed sensor is no good.[/quote:34bcb5f93b]
Thanks! You were exactly right. Replaced the input/output speed sensors and speedometer now works and transmission shifts normally. Your technical expertise is truly appreciated.
Some of you guys that like to fish may want to visit my husband's web site:
www.saltwatersurffisherman.com
An NC Outer Banks fishing web site. We don't sell anything just provide information.
Jun 2, 2007 at 10:46 AM
Suggested Repair
Scan the vehicle for diagnostic codes, then replace the transmission input and output speed sensors if indicated.
Conversation Summary
A 1998 Chrysler Concorde LXI with a 3.2 engine lost speedometer function, illuminated the check engine light, and appeared stuck in second gear. An expert recommended scanning for codes and suspected a failed speed sensor. The owner replaced the input and output speed sensors, after which the speedometer worked and the transmission shifted normally.
