cirrus radiator drain
CHRYSLER CIRRUS
TOM_K
Where is the radiator drain plug on a 1998 Chrsler sirrus? If there is not one, how do I drain the radiator?
Dec 30, 2006 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
If there isn't one, pull the bottom radiator hose.
Jan 1, 2007 at 12:25 AM
STRATUS98
  • 96 POSTS
There is a drain fitting located on the passenger side bottom corner but if you have the v6 model you will not be able to reach this by hand, you can use a universal joint and socket and a long enxtension to remove it.
Jan 2, 2007 at 12:31 AM
