2000 Chrysler Cirrus Transmission Leak
CREN58
  • 5 POSTS
Hi: I have a chrysler cirrus year 2000. recently now another problem has come up. Now I have transmission fluid leaking. I think it is the transmission pan gasket.
will this be very expensive to replace? Is this normal for a car this young to have this go? I have to bring it in to the dealer later today and leave it over night and wont the heads up on what to expect please!
If someone could please help soon as possible it would be greatly appreciated
thanks
Cara
Feb 10, 2006 at 4:15 AM
PEPPERMRJ
  • 1,158 POSTS
Hopefully the problem is already solved. Gaskets can fail for a number of reasons so there is no specific time table for replacement.
the gasket replacement itself is fairly inexpensive however you will need to drain and replace all the fluid to accomplish this. You might as well have the filter replaced at this point. this service should be under a $100.00.
Hope it worked out. :) Let us know.
Feb 12, 2006 at 3:22 AM
CREN58
  • 5 POSTS
[quote:6d94d03e63="peppermrj"]Hopefully the problem is already solved. Gaskets can fail for a number of reasons so there is no specific time table for replacement.
Hope it worked out. :) Let us know.[/quote:6d94d03e63]
Hi had all the above done yesterday on the car but it was much more than $100.00 The total was 244.45
the labor was very high and then the taxes but I am glad that it was done. Hope this is it for a while. Had enough bad luck with the car the last 3 months.
thanks for your reply :o
Feb 12, 2006 at 4:57 AM
PEPPERMRJ
  • 1,158 POSTS
Ouch! Just a suggestion, Ask family, friends, and neighbors for recommendations to a local mechanic.
Their labor prices can be much less for this generic type of service.
Happy (and hopefully trouble free) motoring. :)
Feb 12, 2006 at 5:01 AM
CREN58
  • 5 POSTS
Most of our garages have very high labor charges. Did I mention that we live in Canada maybe thats why?
No matter where I go have tried some garages and they still have high charges. Guess we have to live with these high labor charges. Gone to Canadian Tire, Sears, the actual deal of the car, and other garages but all seem to be around the same.
thanks for all your comments
Feb 12, 2006 at 10:57 AM
Suggested Repair
Replace the transmission pan gasket, drain and refill the transmission fluid, and replace the filter. Labor rates vary by shop; an independent mechanic may cost less than a dealer for this service.
Conversation Summary
A 2000 Chrysler Cirrus owner reported a transmission fluid leak and suspected the pan gasket, asking about cost and whether failure was normal. An expert said gaskets can fail for various reasons with no set timeline, and that gasket replacement plus a fluid drain and refill and filter replacement should be relatively inexpensive, estimating under $100. The owner later reported the work was completed for $244.45 because of high labor and taxes in Canada. The expert suggested asking for local mechanic recommendations for lower labor rates; the owner said Canadian shops they tried charged similarly.
