1999 Chrysler Cirrus Rear Caliper Sticks
Can you compress the caliper back with the bleedr open in the event that the caliper is a defect?
Can you compress the caliper back with the bleedr open in the event that the caliper is a defect?[/quote:450e71eda1]
Yes I can and the new caliper was swapped for another new one to eliminate the posibility of a defective caliper. Could the problem be with the proportioning valve or the wheel hub sensor if not a collapsed brake hose?
Hello Paul, Just to let you know that the problem with this left rear caliper sticking was in fact the brake hose. I had the brake hose replaced (dealer only item) and the caliper is working just fine. The recall you mentioned has been corrected. Thank you for your help.
I dont get the abs light though, well actually i had the abs light on for like 20 mins at one point before all this started
I hope this works this will be my 3rd rear rotor and my 3rd new set of brakes.....
Suggested Repair
Do not assume the ABS hydraulic module is causing the sticking left rear caliper. A collapsed brake hose can act like a check valve and hold pressure. Replace the left rear brake hose (dealer part in this case), then confirm the caliper releases. Also scan ABS codes and verify recall 99V244000 was completed; a proportioning valve is a less likely possibility.
Conversation Summary
A 1999 Chrysler Cirrus had a sticking left rear caliper and an ABS light after the left rear caliper, pads, and rotor and the right rear pads and rotor were replaced and the system was bled. The expert advised against assuming a bad ABS module, noting the ABS system is typically disabled when the light is on, and suggested a collapsed brake hose or a defective caliper. The owner ruled out a bad caliper and later confirmed that replacing the left rear brake hose fixed the sticking caliper. The related recall had already been completed.
