1996 Chrysler Cirrus High Idle
10_SECOND_CIRRUS
i just finished changing my distributer cap and to do so I had to disconnect my throttle cable. when i was done and had everything all set up i went to start my car and as soon as i started it the engine started reving way up so i shut it off. i figured out that my throttle cable was holding my pedal floored. i messed with it a little bit and now when i start the car it revs up to about 2500 and holds. does anyone know what could be causing this? i know i looked at the pedal and if i pulled the pedal out to where it should be i can see about an inch of the cable sticking out. but out of everything ive read i cant figure out whats going on, i was thinking it was just an adjustment but i cant find anything on adjusting it anywhere including my chilton.
Dec 9, 2006 at 12:03 PM
SERVICE WRITER
  • 9,123 POSTS
By chance is there a ton of carbon in the throttle bore causing it to stick?
Jan 2, 2007 at 7:04 AM
STRATUS98
  • 96 POSTS
check the idle air control motor, throttle position sensor, is the pedal still holding down? If it is look for carbon build up, this is easy to do, remove the itake tube from the throttle body with the car off. And move the throttle lever and look into the bore. I don't think you will have much carbon build up but its worth a look.
Jan 2, 2007 at 1:43 PM
Suggested Repair
Confirm the throttle cable and pedal are not holding the throttle open. With the engine off, remove the intake tube, move the throttle lever, and inspect the throttle bore for carbon that could make it stick. Also check the idle air control motor and throttle position sensor.
Conversation Summary
After reconnecting the throttle cable during a distributor cap replacement, a 1996 Chrysler Cirrus idled very high, first as if the pedal were floored and then holding about 2500 rpm. The owner saw about an inch of cable exposed when the pedal was pulled to its resting position and could not find an adjustment procedure. Replies suggested checking whether the pedal still holds the throttle open, inspecting the throttle bore for carbon buildup, and checking the idle air control motor and throttle position sensor.
