1995 Chrysler Cirrus Electrical Issues
HRYSEWYK
I have an automatic transmission, 2.5L V6 engine. A little after I purchased the car the speedometer started freezing while I was driving and would resume working randomly. The I found that my tail lights would also stop working along with my A/C and the dash lights. They don't always all happen at the same time and sometimes it lasts for weeks. I continued driving it and now sometimes when I go to start the car it will turn over and then turn right back off, however when it is running it never stalls or turns off. If I mess with the wiring on top of the computer it starts to work again and weird enough it also starts working when I honk the horn. I'm not really sure what is wrong but I am completely irritated with not knowing when my car will start. PLEASE HELP!
Sep 6, 2007 at 8:51 AM
  • 75,988 POSTS
[quote:24da4cab95="hrysewyk"]I have an automatic transmission, 2.5L V6 engine. A little after I purchased the car the speedometer started freezing while I was driving and would resume working randomly. The I found that my tail lights would also stop working along with my A/C and the dash lights. They don't always all happen at the same time and sometimes it lasts for weeks. I continued driving it and now sometimes when I go to start the car it will turn over and then turn right back off, however when it is running it never stalls or turns off. If I mess with the wiring on top of the computer it starts to work again and weird enough it also starts working when I honk the horn. I'm not really sure what is wrong but I am completely irritated with not knowing when my car will start. PLEASE HELP![/quote:24da4cab95]
If I mess with the wiring on top of the computer it starts to work again, a good place to start making sure the wiring connectors are engaged properly with the PCM
Sep 6, 2007 at 9:20 AM
Suggested Repair
Inspect the wiring on top of the PCM and make sure the connectors are fully seated and properly engaged.
Conversation Summary
The owner of a 1995 Chrysler Cirrus LXI with a 2.5L V6 and automatic transmission reports intermittent speedometer freezing, tail lights, A/C, and dash lights failing, plus occasional crank-then-stall on start. The car does not stall once running, and symptoms sometimes clear when the wiring on top of the computer is disturbed or when the horn is honked. The expert recommends starting by confirming the wiring connectors are properly engaged with the PCM.
