My problem today is that the engine light is on and the car is smoking...not from the rad but under the hood and the temperature gauge is maxed out hot after 30 minutes of driving. All fluids are good.
Help, what is wrong and Thanks in advance.
Repair the power steering leak first. Check whether leaking fluid is wetting the drive belt and causing it to slip, which can stop the water pump from turning and make the engine overheat. The under-hood smoke may be burning power steering fluid.
The owner of a 1996 Chrysler Cirrus reports an illuminated engine light, under-hood smoke not coming from the radiator, and the temperature gauge reaching maximum after about 30 minutes of driving. Coolant and other fluids are reported full, and there is also a power steering leak that adding fluid does not resolve. The expert says the leak should be repaired and that burning power steering fluid may cause the smoke; fluid on the belt could make it slip so the water pump does not turn, leading to overheating.
