2000 Chrysler Cirrus Battery Light
NBLACK20
  • 10 POSTS
2000 Chrysler Cirrus LXI, 65,000 mi.
About 2 mos ago my wife noticed the battery light was on. When she got home she shut it down, restarted and light went away. Last month light came on again this time stayed on several days till I got home and when I started the car the light was out. This time light on again and it's been 3 days. I'm just hoping it'll wait till I get home. Any ideas?
Jul 12, 2006 at 4:16 PM
VANDRAGON
  • 298 POSTS
when was the last time you replaced the battery or charged it? also check the battery conncetions, or it could be altenator time. just call autozone and ask them.
Jul 12, 2006 at 11:33 PM
NBLACK20
  • 10 POSTS
I changed the battery about 2 yrs ago. And the light just went out. If it was the battery or altenator why would the light be on intermittant
Jul 13, 2006 at 7:15 AM
SYNCRAIT
  • 235 POSTS
i would reccommend checking the alternator belt if you have already gone through all the connections it could just be the the belt is slipping more sometimes than others....good luck :)
ps. make sure your grounding from the battery to the frame is clean and secure
Aug 8, 2006 at 5:40 AM
Suggested Repair
Check battery condition and connections, clean and secure the battery-to-frame ground, test the alternator, and inspect the alternator belt for intermittent slipping.
Conversation Summary
The owner of a 2000 Chrysler Cirrus reports an intermittent battery light that comes and goes over several days. Experts suggest checking the battery, connections, alternator, belt slip, and grounding.
