1999 Chrysler Cirrus Fan Only With A/C
GARRYGARFISH
I HAVE A 1999 CHRYSLER CIRRUS, THAT THE COOLING FAN DOES NOT COMR ON WHEN THE A/C IS OFF. THE COOLING FAN COMES ON ONLY WHEN THE A/C IS ON.
Mar 4, 2007 at 3:40 AM
RETIREDAUTO
  • 46 POSTS
sounds like you need to locate and test cooling fan switch. try that not really sure of it's location but i think it is on the intake manifold probably 2 wire conn.'when u locate it unplug it w/key on jump it and se if fan comes on. good luck
Mar 4, 2007 at 6:04 AM
2CARPRO JACK
  • 11,533 POSTS
First, with car off reach in and try to spin the motor.Have replaced tons of Chrysler electric fan motors.
Mar 4, 2007 at 11:09 PM
Suggested Repair
With the engine off, try to spin the cooling fan motor by hand. If it does not turn freely, replace the electric fan motor, a common failure on these Chryslers.
Conversation Summary
The owner of a 1999 Chrysler Cirrus said the cooling fan runs only when the A/C is on and does not come on with the A/C off. Another reply suggested locating and jumping the cooling fan switch. The expert advised checking whether the fan motor spins freely with the car off, noting that many Chrysler electric fan motors need replacement.
