No brake lights?
RATLIFF
  • 1997 CHEVROLET TRUCK
  • V8
  • 261,000 MILES
How would I check this? All my brake light fuses work, but my brake lights still will not work. I know the voltage under pedal should be 12, but I am not sure how to check to see if this is the problem.
Saturday, November 21st, 2020 AT 5:09 PM (Merged)
MASTERTECHTIM
  • 4,749 POSTS
Put a test light to the white wire and it should light when you apply the brakes. Also the orange wire should be hot at all times. If light on orange wire but no light on white, replace brake light switch, if light on both suspect turn signal switch, hope this helps
SHUFF2249
  • 11 POSTS
  • 1995 CHEVROLET TRUCK
  • V8
  • 16,500 MILES
Left brake light is not working. Have replaced bulb and circuit board. Tail light and turn signal work fine. PLEASE HELP
Saturday, November 21st, 2020 AT 5:10 PM (Merged)
JDL
  • 16,098 POSTS
Hello, I'd have to check the turn switch. Your lower brake lites and turn signal are wired through the turn switch, use the same wiring circuit and bulb filament, just not at the same time.
J_DIDDY69_01
  • 5 POSTS
  • CHEVROLET TRUCK
1998 C1500 5.0. My brake lights have recently stopped working on my truck. Both of the brake lights in the tail lights would not work and one of the two lights on the cab brake light was not working. It turned out to be a bad buld in the cab light so they are fine now but the tail lights still are not working. I can hear the relay working properly, the parking, reverse, and turn signals are fine just the brakes. When the brakes are pressed it is getting about 12.5 volts to the socket (between the positive and the ground in the socket) but still no lights. I can visibly see the bulb is fine but even tried it with others just in case and still nothing. The ground seems to be fine, the power seems to be there, this makes no sense to me anyone have any ideas?
*After checking many different scenarios I found that the socket is getting 12v when the bulbs are out of both lights but if I put a bulb in either light it will not read any voltage at either light. Does anyone know what would cause this?
Saturday, November 21st, 2020 AT 5:16 PM (Merged)
CZECHMIX
Have you resolved this issue (I see it's been almost 2 months since your post)? I have the same truck, and the same issue with my right rear turn signal. Same symptoms. Bulb is fine, voltage is fine. I found that the di-electric grease (tan colored gunk inside the bulb socket) had dried up, turned a dark brown color, for whatever reason. I used a fine-tipped tool to scrape the old crud out of the socket, and sure enough the light once again worked like a charm. However, this only worked for about a month, and now the light works intermittently. I am going to replace that plastic socket assembly (the thing that holds all 3 bulbs) and see if that fixes it.
BAGA58
  • CHEVROLET TRUCK
1998 Chevy Pickup, 165,000 miles. I have no brake lights, the third light up top works fine, as do all running lights, turn lights, back up. But no brake lights. I have replaced the brake switch( 2 of them, one was DOA out of box!), Brake relay under the hood, all bulbs. I have traced all wires all the way to the back, they are fine. I can take a wire that is 12v hot and touch it to the wires that go back and I get brake lights. Is there some part that makes the turn signal and brake power go together or is it done in the break switch? What other parts are in the system?
THANK YOU FOR YOUR TIME AND HELP !
George
CLY
  • 308 POSTS
The highmount brake light feeds from the brake switch and the lower brake lights run through the turnsignal switch assembly. More than likely you have a faulty turnsignal switch.
Cly
BAGA58
Ok, I was thinking that my problem was somewhere in that area. Where could I find the turnsignal switch assembly at? Is that where the power 12v from brake light and signal come together? THANKS FOR YOUR HELP !
CLY
  • 308 POSTS
The turnsignal switch is located in the steering column. You have disassemble the top of the column to replace it.
Cly
