The traction control unit is designed to limit power in the event of slipping. However, it should not stall the engine.
Have you checked for diagnostic trouble codes? That is the first thing I would suggest. Here is a quick video showing how a scanner is used to retrieve that information:
https://youtu.be/YV3TRZwer8k
Often times, a traction control issue is the result of a faulty wheel speed sensor. However, it needs scanned to determine if that is the problem and which sensor it the cause.
I realize most people do not own a scanner. However, most parts stores will do it for free.
Do this and let me know what you find.
Oct 10, 2020 at 3:47 AM
(Merged)
