1989 Chevy Camaro will not start unless
OTHG748
  • 1989 CHEVROLET CAMARO
Engine Mechanical problem
1989 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i have an 89 camaro w/ 2.8 L mpfi engine it will not start unless I use just a shot of carb cleaner once it starts all is good so I think fuel press should be o.K.? Is there a choke on mpfi motors cant find the answer to the choke? Dont have a job cant donate now thanks allen
Thursday, April 29th, 2010 AT 2:11 AM
Fuel injected engines don't have a choke-Check the fuel pressure if its within specs if okay test the fuel pump relay.
Saturday, August 17th, 2019 AT 4:52 PM
OTHG748
Razmataz had a bad wire on pump relay tried to start but was struggling to run, ? Found that the plugs were gapped at 30 regapped to 45 it runs GREAT NOW thanks again if I get alittle extra$$$$$ I WILL donate, thanks much Allen S.
