Check for trouble codes. Place a jumper wire between the A&B terminals of the data link connector, turn the ignition key till the dash lites come on, no crank. The check engine lite should start flashing, you count the flashes to get the codes, if there are any. You might check fuel pressure, some of the national brand autostores will loan pressure gages and other tools. You may have to put up a deposit, but, you get it back, when you return the tool.
SPONSORED LINKS
Friday, December 5th, 2008 AT 9:41 AM
