5.7 litre tuned port injection. Occaisionally the car will not start, cranks but wont fire. You can spray inside the intake with carb cleaner and then it will start right up. Have checked fuel pressure and even when it does this it still holds 41 psi. Have also tried replacing the mass air flow sensor and it still did it. It will do this maybe once every 10 times you start it. Not recieving any codes through the check engine light.
Jul 2, 2010 at 10:37 AM
