have spark, fuel,
Mar 13, 2007 at 3:13 PM
Check fuel pressure and inspect the fuel pressure regulator and fuel return line, since fuel was leaking on the plenum and the plugs were fuel-fouled. Also verify valve and ignition timing and rule out a large vacuum leak if pressure is normal.
A 1989 Chevrolet Camaro V6 would not start despite having spark and fuel. The expert advised checking spark quality, fuel pressure, valve and ignition timing, vacuum leaks, and compression. Compression was good, but the plugs were fuel-fouled and fuel was leaking on the plenum. The expert then recommended checking fuel pressure and inspecting the pressure regulator or an obstructed fuel return line.
