1997 Chevrolet Blazer Rear Window Latch Fix
TENA
I have a 1997 chevy s10 blazer, 4x4, automatic, 4 door with rear window and hatch that work with key button to open window then reach inside to open bottom hatch. I can hear noise when I push the button but the window will not release. I used it all day then one time it would not open, bummer since my job is delivery.
My question is what kind of repair shop should I take it to, body? auto? chevy dealer? Or is it simple enough to fix myself.
thank you for your help
Tena
Sep 12, 2007 at 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
You can do it yourself.Crawl in through the back seat and remove th einterior panel off the bottom door.You should have access to that point to the latch assembly. Have someone push th erelease button and you should be able to watch it so you can see whats wrong.Since you do delivery, I would guess the latch itself is probably broken due to the amount of usage it gets
Sep 13, 2007 at 12:56 AM
Suggested Repair
Remove the interior panel on the rear hatch from inside the vehicle and watch the latch while someone presses the release button. Heavy use may have broken the latch, which may need repair or replacement.
Conversation Summary
The owner of a 1997 Chevrolet S10 Blazer says the rear window release makes noise but will not open the window, so the lower hatch cannot be opened from inside. An expert says the owner can remove the interior panel, observe the latch while the button is pressed, and that frequent delivery use may have broken the latch.
