1993 Chevy Blazer Injectors and Window Squeak
CHEVYMAN90
i have a 1993 chevy s10 blazer and i was wonder where the fuel injectors are located? i also have a problem with my rear window squeaking every time i go down the road, how do i fix this?
Aug 22, 2007 at 10:47 AM
  • 75,988 POSTS
[quote:593d28dfd5="chevyman90"]i have a 1993 chevy s10 blazer and i was wonder where the fuel injectors are located? i also have a problem with my rear window squeaking every time i go down the road, how do i fix this?[/quote:593d28dfd5]
You probably have a 4.3vortec CPI its under the manifold tuning center top of engine. You have to remove it to get to it.
Aug 22, 2007 at 7:20 PM
RAYT333
  • 27 POSTS
As to the rear window, try appling some grease on the latch itself. Check it to see if it has wear on the piece that goes into the latch, if it has worn too much then it will not latch tight and will rattle.
Also check the mounting bolts at the top of the window, I have seen them get loose and cause a rattle as well.
Nov 2, 2007 at 1:20 AM
Suggested Repair
On a 4.3 Vortec CPI, the fuel injectors are under the manifold tuning cover at the top center of the engine and the cover must be removed to reach them. For the squeaking rear window, grease the latch, inspect the latch striker for wear that prevents a tight latch, and check that the upper window mounting bolts are tight.
Conversation Summary
The owner of a 1993 Chevy S10 Blazer asked where the fuel injectors are located and how to stop the rear window from squeaking while driving. One reply said a 4.3 Vortec CPI system has the injectors under the manifold tuning cover at the top of the engine, which must be removed for access. Another suggested greasing the rear-window latch, checking the latch striker for excessive wear, and tightening loose upper mounting bolts.
