1996 Chevy Blazer Door Hinge Pins
SCOTT BAUER
i have a 1996 chevy blazer with 195,000 miles. can you buy kits to repair hinges? if so how do you do it ?are there any special tools needed?
Nov 11, 2006 at 4:05 PM
JBECHEL
I have the same problem, did find they sell door hinge pin & bushing kits, but I am also trying to find out how to replace them before i purchase kit.
May 3, 2012 at 8:09 AM
  • 110,248 POSTS
You can get the kits to replace the hinges. They are cheap and no special tools are required. You simply support the door, remove the old pins and replace them.
Jun 25, 2012 at 7:05 PM
Suggested Repair
Purchase a door hinge pin and bushing kit. Support the door, remove the old pins, and install the new pins and bushings. No special tools are required.
Conversation Summary
The owner of a 1996 Chevrolet Blazer with high mileage asked whether door hinge repair kits are available, how to install them, and whether special tools are needed. Another user confirmed pin and bushing kits are sold. The expert said the kits are inexpensive, no special tools are required, and the repair is done by supporting the door, removing the old pins, and replacing them.
