1998 Chevy Blazer Intermittent Wipers
QUEENREDBULL
  • 6 POSTS
Ok I just bought a 1998 Chevy Blazer, 123,000miles and the winshield wipers work when they want to. So if i would pull on the arm of the wiper a little bit they would start working. I was wondering if you know what this could be? Also last night when i pulled the arm on the wiper a little bit to try to get them going again I heard a snap so now the drivers side windshiel wiper dont always move up with the other one. Can you PLEASE help me fix this
Thank You
May 10, 2007 at 4:41 AM
BOOTDOG
  • 665 POSTS
you've might have pulled the wiper off the mechanism to where it's not tight against it. or you may have broken the wiper arm lock. if so replace the wiper arm. to fix it wipers you'll need to replace the wiper module. it's very simple to replace and inexpensive. it's located behind the black square plate on the wiper motor. unplug the harness, remove the plate and swap with the new one.
May 10, 2007 at 8:09 AM
QUEENREDBULL
  • 6 POSTS
Thank You I will try that I am greatful for the help. Thanks again
May 10, 2007 at 8:35 AM
Suggested Repair
Check whether the wiper arm has pulled loose from the mechanism or the arm lock is broken, and replace the wiper arm if needed. Also replace the wiper module behind the black square plate on the wiper motor: unplug the harness, remove the plate, and install the new module.
Conversation Summary
The owner of a 1998 Chevy Blazer reported intermittent windshield wipers that would start after the arm was pulled. After a snap, the driver-side wiper no longer always moved with the other. The expert said the arm may be loose or the lock broken and recommended replacing the wiper arm if needed, plus replacing the inexpensive wiper module on the wiper motor.
