1995 Chevy Blazer Rear Washer No Spray
BLAZERCHAD
I have a 1995 chevy blazer. 160,000 miles. No rear windshield wiper fluid will spray. There is plenty fluid in the tank and it works fine in the front. Any suggestions?
Jul 11, 2006 at 3:12 AM
MIKEYBDMAN
  • 623 POSTS
Ok, if your tail gate wiper works but not your washer, then you wither have a bad tailgate washer pump, or a break in the washer fluid hoses.
I would suggest taking the inner panel of the tail gate off and gaining access to the pump. See if it is working to start with. If not, check pin A on the plug for a good ground, and pin B for 12 volts when the washer switch is selected to wash. If you have both, and the pump is not running, replace it. It uses the same power to run the wiper in the wash mode as to run the washer pump in the wash mode, so if your wiper is wiping, your pump should be pumping. If your pump is working, then check the hoses from the resevoir to the pump, and from the pump to the spray nozzle for breaks or cloges.
Good luck.
Jul 13, 2006 at 8:58 AM
Suggested Repair
If the tailgate wiper works but the rear washer does not spray, inspect the tailgate washer pump and hoses. Remove the tailgate inner panel and confirm the pump runs. If it does not, check pin A for a good ground and pin B for 12 volts with the washer switch selected; replace the pump if power and ground are present. If the pump runs, inspect the hoses from the reservoir to the pump and from the pump to the nozzle for breaks or clogs.
Conversation Summary
The owner of a 1995 Chevy Blazer with 160,000 miles reports that the rear washer will not spray despite fluid in the tank, while the front washer works. The expert says a working tailgate wiper with no spray points to a failed tailgate washer pump or a broken or clogged washer hose. They recommend accessing the pump through the tailgate inner panel, verifying ground and 12-volt power at the connector, replacing the pump if it has power but does not run, and checking the hoses if it does run.
