1998 Chevrolet Blazer CV Boot Leak
DCHRIS1981
  • 12 POSTS
I have a 98 chevy blazer w/4x4 and the front right side. the cv boot has a green oil that's splating around the boot? dose it just need a new boot or do i have to replace the whole thing? dont hear any sounds or feel anything from around their while driveing just seen the oil . is that something that normaly go's bad ?
Apr 2, 2006 at 10:50 PM
LOSONE
  • 1,616 POSTS
The green oil is really green CV joint grease. have the boot replaced as soon as you can to prevent damage to the joint.
Apr 3, 2006 at 12:29 AM
Suggested Repair
Replace the torn CV boot as soon as possible so the joint does not lose grease and become damaged. The green fluid is CV joint grease, not oil.
Conversation Summary
The owner of a 1998 Chevrolet Blazer noticed green fluid splattering from the front right CV boot but reported no noise or driving symptoms and asked whether only the boot or the whole joint needed replacement. The expert identified the fluid as CV joint grease and recommended replacing the boot promptly to prevent joint damage.
