Head Lights
MICHAEL WADMAN
I have an 02 Blazer, I recently replaced a Head Light bulb. The replacement bulb shines a good 3" higher than the other. Is there a way to adjust the Head Lights so they are level with each other?
Jan 19, 2006 at 2:41 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like the bulb isnt in right or the headlight isnt in the core support right, bulbs rarely change the adjustment
Feb 3, 2006 at 7:51 AM
MICHAEL WADMAN
Actually the bulb is the correct one and it was out of alingment. However there is a vertal adjustment post located on the top of the outer frame of the headlight assembly, It's actuall just under the hood. You hve to be somewhat careful because after you make the adjustment and close the hood the lights may still be out of alingment because of the preassure the hood places on the frame.
Feb 10, 2006 at 4:18 AM
