95 blazer 4.3 parking lights stay on??
1995 CHEVROLET TRAILBLAZER
ALAN567
i have a 95 s10 balzer 4.3and the parking lights wont shut off replaced head light switch still didnt fix any ideas???
Feb 19, 2007 at 8:00 AM
CHEVY22
  • 1,375 POSTS
was it replaced with a new switch aand did the lights not go off before you replaced the switch??
thanks
Feb 19, 2007 at 8:15 AM
ALAN567
yes it was replaced witha new switch still didnt go off .. also when switch was un plugged the lights stay on
Feb 19, 2007 at 8:24 AM
CHEVY22
  • 1,375 POSTS
uh oh , there is a short somewhere how are you on electrical problems , i can help but you would have to have some knowledge of 12v systems and diagnosis
Feb 19, 2007 at 8:29 AM
ALAN567
im pretty good just not sure where to start on this,i wish i had the wiring diagram on it
Feb 19, 2007 at 8:32 AM
CHEVY22
  • 1,375 POSTS
ok , lets start here , there is one red wire from the fuse box to the headlight switch ,the parking lamp circuit is a brown wire and runs to the interior light and to the rear and splits off to the tail lamps,
i would pull the courtesy lamp fuse and see if the park lamps go out if they go out there is a problem inside like a short in the dome lamp
but either way there is a short to ground powering the park lamp circuit through the switch at all times
do you have a hitch and wiring if so check the brown wire there ive seen them rub the frame before ,
let me know
Feb 19, 2007 at 8:40 AM
ALAN567
ill try that first,, i do have a hitch forgot all about that,ilet me get at it
Feb 19, 2007 at 8:51 AM
