1997 Chevrolet Blazer Left Signals Stay On
JYENDALL
Issue: Left interior turn indicator light stays solid when activated, as do both left exterior turn indicators. Right system functions normally.
Grateful for some guidance on what might be the problem and solution.
Thanks.
Jan 17, 2006 at 3:51 PM
ARKOSE
  • 19 POSTS
Check the flasher circuit output voltage. It should alternate causing the light to flash. If you have a constant voltage then I would replace the flasher. I believe you can order a new one at your local auto parts store.
Jan 20, 2006 at 6:36 AM
SC1 RACING
  • 117 POSTS
check the bulb housings on the left side. you have something shorted out, or if it started while it was raining or washed you have moister in the bulb housing.
Jan 20, 2006 at 6:39 AM
Suggested Repair
Inspect the left-side turn-signal bulb housings for a short or moisture, especially if the problem began after rain or washing. Dry the housings and repair any corroded sockets or damaged wiring.
Conversation Summary
A 1997 Chevy/Opel Blazer has a left turn signal that stays solid on the interior indicator and both left exterior lamps, while the right side works normally. One reply suggested checking flasher-circuit output voltage and replacing the flasher if the voltage is constant. The expert advised checking the left bulb housings for a short or moisture.
