1999 Chevrolet Blazer Turn Signal Clicking
IZECOLD
My 1999 Blazer needs help. The turn signal sound stays on all the time. It is anoying but everything works great. Turn signals work and hazards . Just the clicking noise won't stop unless the break pedal is pushed in. How do i fix this problem? please help......
thanks
Apr 16, 2006 at 2:36 AM
LOSONE
  • 1,616 POSTS
Thats the second question today on the same problem. It sounds like the energency flasher portion of the turn signal sw may be bad causing the problem but the main suspect is the turn signal sw. Good luck
Apr 16, 2006 at 3:14 AM
Suggested Repair
Inspect and likely replace the turn signal switch. The expert suspects the emergency flasher portion of the switch is faulty and causing the continuous clicking.
Conversation Summary
The owner of a 1999 Chevrolet Blazer reports that the turn signal clicking continues all the time even though the turn signals and hazards work normally. The clicking stops only when the brake pedal is pressed. The expert identifies the turn signal switch as the main suspect, specifically a possible fault in its emergency flasher portion.
