1999 Chevrolet Blazer Turn Signal Noise
IZECOLD
My 1999 Blazer is making the turn signal noise continuously. It won't turn off unless you press on the brake pedal. The turn signal and hazards work pervect but that anoying noise stays on all the time. What could be the problem?
Apr 15, 2006 at 8:00 AM
LOSONE
  • 1,616 POSTS
If the noise is from the flasher units then the turn signals or flasher can't work perfectly. It sounds like you need to replace one or both flashers, They are cheap and worth a try.
Apr 15, 2006 at 10:52 AM
IZECOLD
[quote:81d15e968e="losone"]If the noise is from the flasher units then the turn signals or flasher can't work perfectly. It sounds like you need to replace one or both flashers, They are cheap and worth a try.[/quote:81d15e968e]
How many flasher units are in the blazer. I already replaced one and it didnt fix the problem.
Apr 17, 2006 at 10:28 AM
LOSONE
  • 1,616 POSTS
There are 2 one for the hazard flashers and one for the turn signals.
Apr 17, 2006 at 10:37 AM
Suggested Repair
Replace both flasher units: one for the turn signals and one for the hazards. They are inexpensive, and replacing only one may not stop the continuous clicking.
Conversation Summary
The owner of a 1999 Chevrolet Blazer reports a continuous turn-signal clicking noise that stops only when the brake pedal is pressed, while the turn signals and hazards otherwise work. An expert said the noise likely comes from a flasher and recommended replacing one or both units. After one replacement did not help, the expert clarified that the Blazer has two flashers, one for hazards and one for turn signals.
