Heater core?
CWPWELB
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 195,000 MILES
What is the location of all the bolts for dash removal.
Wednesday, August 19th, 2020 AT 8:25 PM (Merged)
SWILLIAMS
  • 597 POSTS
You will find two under the dash, one on each end. Then there are two hidden under the speaker grills on the dash and two more under the center vent grill. There are also two toward the middle of the dash behind the radio plus the ones that secure the dash to the steering column bracket and depending on options the center console has one above it going to a brace. I think that's all. I've slept since I pulled a dash on a 95. :-)
2CP-ARCHIVES
  • 4,540 POSTS
  • 1994 CHEVROLET BLAZER
  • 160,000 MILES
How many hours labor from an mechanic to replace heater core
Wednesday, August 19th, 2020 AT 8:26 PM (Merged)
JDL
  • 16,098 POSTS
My spec for factory says 2.2 hrs. Sometimes that factory spec isn't realistic. My labor specs says factory--regular--severe, the severe is close to 4 hrs.
SHONKACZ
1994 Chevy Blazer
need to change heater core where is it
  • 109,951 POSTS
It is located under the dash and requires many things to be removed. I recommend that you purchase a repair manual that provides step by step instructions and pictures to identify parts.
CANIBEINYOURWORLD
  • 1993 CHEVROLET BLAZER
Heater problem
1993 Chevy Blazer Four Wheel Drive Automatic
how do you change the heating core of a chevy blazer. My uncle is trying to change one and he can't figure out how to get the old one out and the new one in.
GEARHEADWHIT
  • 5 POSTS
Go to autozone. Com and check their repair guides - it's free
GUITRMAN56
  • 1989 CHEVROLET BLAZER
  • V8
  • 4WD
  • 200,000 MILES
We have to re and re the heater core. Is it do-able in a day's time? Also, I have heard that a small section of the air duct can be cut and taped over so u can cut the re and re time down. (It's cold outside. Grinzzz!) Thanks.
  • 109,951 POSTS
Hi:
You could do it in a day. However, I don't recommend cutting things. You'll end up with other problems. I do recommend that you purchase a repair manual because it is involved process.
JERRYDD
  • 1988 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 150,000 MILES
Does the dash board have to be removed to change the heater core
DOCFIXIT
  • 18,828 POSTS
No remove glove box, duct work, cable three nuts that protrude through firewall.
PIATTGIRL
  • 1983 CHEVROLET BLAZER
Heater problem
1983 Chevy Blazer 6 cyl All Wheel Drive Manual
how do I change the heater core on my 83 blazer I have antifreeze coming into the car an its all wet on the passnger side of the floor an when I turn on the heater you can smell antifreeze
  • 31,937 POSTS
HI there,
See text for procedure , there are no pics to support this operation sorry.
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_1_103.jpg
