Yes, since you already had it running earlier you should run it again. Also can your scan tool do active tests? I want to know if you can active test the oil control valve. If you already replaced it then drive it to verify there are no timing codes set.
SPONSORED LINKS
Thursday, September 26th, 2019 AT 5:24 PM
